I got all four new transmission mounts for the 2010 Toyota Matrix from Toyota and decided to put them today. I watched videos all day yesterday to get ready for today. So, i started with the rear mount since it is the most difficult and i managed to get it out without as much trouble as i thought it was gonna be. However once i put the new one back and tried to line up the hole in the mount with the holes on the bracket it was impossible. i had the car jacked up and tried to use scissor jacks separately to lower and raise the transmission from the pan and from the actual transmission and even the engine. I then lowered the car to the floor and tried jacking up the transmission alone. I also tried lining them up by loosening the anchor bolts from the mounts but to no avail. the same thing happened with the passenger transmission mount, it won't line up. I did the front mount, no problem. I called it a nigh after many many hours and will try again on wednesday which is my next day off but i feel like i'm not gonna get anywhere. Every video i watched says to jack it up and down until you get lucky but as you can see in the picture is not just a matter of up and down, the hole in the rear one not only is higher but it seems to be pushed backwards. Here are the pics for reference. Please Help!🙏🙏
