What do you keep in your bed storage?
6.6K views 45 replies 40 participants last post by  switch
Seriously.
I have been sitting here thinking to myself, "What in the hell is supposed to go in those little compartments?!". Right now I have a couple cheap pieces of rope that I don't care if it gets stolen but in there.
If I did the Lock DIY I wonder if I could use it to keep a tow strap in??
What do you guys put in those little cubbys?
#11 ·
I have the fix a flat plug, 2 bottle of brake cleaner and a WD 40 on the large and the small.. I have the red flag for long item extended to the back and a small piece of rope.
Never thought about the hitch mount would fit in the big compartment since mine is a 4 1/2 inch drop. I would just leave it on to keep A$$ hole from tail gating me. :D
#20 ·
The fix-a-flat foam bottle is not supposed to be used on tires with pressure sensors, it could jack them up. I used to keep one if the truck at all times until I read that. I'm at work and in a hurry, otherwise I'd find some evidence to back it up.
#13 ·
3 tie down straps
1 rag (should be red)
1 LED lantern
1 lightbuster
1 Dog leash clip
#21 ·
I Kiteboard and keep my dirty Wetsuit Booties in the large one. Nobody would ever consider stealing those things. I usually leave the small one empty, and aside from the occasional empty water bottle or aluminum can, the two other open compartments in the bed also remain empty.
I leave my tie downs, bungees, rope, bags, fix-a-flat foam bottle, etc under the rear seat (Double Cab). Oh, and I don't have the tire pressure sensors, so the fix-a-flat foam is a good option and has already proven its worth when I ended up getting multiple flats.
#22 ·
A couple of Rat Traps so when some a-hole crack head tries to rip me off he might loose some fingers!!
#25 ·
Would have been nice if they got rid of the boxes and made the whole bed wider instead. So much wasted space between bed wall and outer body...
Anyway, what goes in? Muddy socks/gloves, trailer hitch plug, trash, or pack with snow and beer.
#26 ·
I used to keep bungee cords in there but now nothing. Stupid cover keeps unlocking itself and falling off. Holding it on with duct tape right now. I really should do the lock mod but I'm too lazy for something so simple right now.
#27 ·
I had kept some ratchet straps and jumper cables in there but they got really dirty and the straps got too stiff. Prob the AZ heat and dust will destroy anything in there. Might try wrapping them in garbage bags and see how they hold up.
