can someone explain this concept to me? is that a real thing or a myth?
What new values are you referring to?It all depends on what you define as learning. If the ECM takes the new values that it has obtained over a period of time and applies them to better manage the fuel system then it has learn something. It is kind of like us working on cars, we make repairs one way the first time, then the second time around we do it differently and save time. In other words, we have learn something in order for us to shorten the time. Same for the ECM when it utilize the new information that it had obtained to better manage the fuel system then it is learning.
In some sense, the new ECMs are capable of learning, but not to the point of thinking and making intellectual changes for and by themselves. At least not yet, but maybe it is just around the corner.
So, what and how do you define learning?
N.E.O.
The ECU is only remembering how it was programmed by/for person/driver #1 and by/for person/driver #2. If it's never programed it will never know, or distinguish between, person/driver #1 or person/driver #2, regardless of time, nor will it learn #1 and/or #2 over time.:thumbsup:.......there are vehicles out there that can distinguish drivers by means of the key fobs. When the drivers walk up to the car, the key fob signal will notify the vehicle's system to adjust seat position, steering wheel position, A/C system setting, and radio station preference all without any further interaction by the driver when he or she enters the vehicle.........
I thought I was the one that "doesn't believe the ECU learns" so again, I don't have a definition of ECU learning, just following programming and analyzing info from sensors.So your definition of computer learning is .........?
You are right about under hard acceleration the fuel control may go into open loop; however, do you drive like that all the time?
What do you consider technical info/proof?
N.E.O.
