what if.... you lost your tranny fluid???
1.2K views 4 replies 5 participants last post by  fenixus
OK so my tomtom took me down a road today that really wasnt a road. it was more like a very rocky cow trail. and this cam seems to scrape on damn near anything.
Since it does sit low to the ground, I was wondering what the hell woodve happened if i would have gouged or ripped a hole in the tranny pan, and it dump the fluid... or if one of the hoses leading to the rad was to bust? I dont think there is a warning lite for that on the dash! Im guessing the car would drop into neutral and not go. But would this trash the tranny? cuz that wood rlly suck. This car has a great trans in it. just wondering if i should upgrade those rubber hoses with steel braided ones when i add my tranny cooler... maybe add a skid plate to protect it.... ?
#2 · (Edited)
If the fluid drains out, it would slip and then go into neutral as there is no ATF to provide pressure to the clutch packs. IMO, the oil pan and trans pan is tuck up quite well. I think the cooler lines should be fine as they are routed between the tranmission and radiator. I have driven into deep grooves and washboard but most of the beating was on the exhaust and sub frame.
What you need to do is switch out that Tomtom for a Garmin. J/K
If the transmission last fluid and can't function and you stopped and had the car towed, then there is a good chance everything is will still work ok when you fix the leak and refill.
You can also clean the pan this time, and then drop the pan say after 7500 miles and check for debris.
I think the only way to make a hole in trans pan is to be very unfortunate and hit a rocky sharp bump with it as normally the sub-frame and exhaust (as mentioned above) take all the scratching first, then the oil pan and lastly the trans pan ... so your car would be pretty much done before the trans pan got ripped ... unless you were VERY unlucky, just saying ;)
EDIT:
you should go to your GPS navigation/map settings and select Avoidance for non-asphalt/rough roads (or off roads or whatever it's called) ... at least I have that in my Garmin ;)
also set that navigation for fastest routes, not the shortest ones ;) shortest doesn't mean quickest hehe
