what motor will fit my all trac sedan
2.8K views 14 replies 6 participants last post by  cuzman
its a 1989 corolla all trac sedan with 4A-FE and auto trans with overdrive. what motors will fit the trans that i got? what parts will i need from the other car that i get the motor from?
#2 · (Edited)
Any A series will bolt up, however the 4afe's have a 6 bolt crank and most 4ages are 8 bolt. so you would need an 4age 8 bolt flex-plate (and possibly torque converter) to bolt it up.
IMO its not worth doing a 4age swap if your planning on running an auto.
As for other parts you will need, 4age Loom and ECU, and axillaries (starter/alternator/PS pump).
A search will turn up these answers if you can be bothered.
With regards to the wagon/sedan the ones we recieved (NZ) were the same.
What motor would I put in??
I'd leave the standard one in and just save up and buy a better car.
But hey thats just me, All I can say is price up your options, 4age swaps seem to be extremly expensive over there.
Answer these questions
1. Why do you want to change the motor in you car?
2. What do you want to end up with? (Ie. performance goals)
3. Whats you budget
4. Can you do the work yourself?
4age's have practically no low end power
a 4age block will NOT bolt up.... something about the tranny is slightly different... you would need to use your engine block and get early (85/86) 4age internals...
an 8 bolt flexplate and 4age torque convertor is easy to find.... i actually have them lying around here
#9 ·
there's an indentation that the FE motors have that the ge's didn't... (including the 7a).... something on the tranny, apparently
i went over this in another thread... this info was from a guy over on mr2oc.com who used to rally the sedans, and had run into this problem...
#12 · (Edited)
Maattte! from aussie here ...done it! You will need the flywheel/t/coverter etc and it will bolt up! no prob..
now heres the prob
One of the bolt mounting points for the cetre diff need to be grinded back bout 1/4 inch i used an angle grinder..its good still works no stress probs
All of my 20v motor is std hence the alt is on the other side ..wiring issues
You cant fit the super charged 4age16v as the charger is were the centre diff is!
If you need more info justinlinton@hotmail.com or just re post
