Hey guys. So I have an 08 CE and im kind of sick of the stock 185/65r15 wheel look. I was thinking about going a little bigger, maybe to a set of Motegi Racing MR131's that are 17x7 with a 45mm offset and 5x100mm bolt pattern. I would also be going up to a tire size of 205/45r17 to fit the new rims and still not be too big for the wheel well. Has anyone else tried going to a 17 inch rim here? And if so what tire size did you end up going with? I'm pretty set on 205s as I've heard they fit just fine with no rubbing issues, but not certain on the best tire ratio, though if heard 45 or 50 will fit just fine. Rim pictured below.
