I have a 1994 camry LE, with the I4. Its a coupe. How do I know what diameter the rear sway bar is, because I need to replace the bushings and they offer a 15/16mm, and a 17mm. Thanks, any advice appreciated.
I looked at my 96 camry, and the sway bar appeared to have some kind of plastic coating which was torn off around the bushing. so maybe it uses 17mm with the plasticoating, and 15/16mm without the coating.
Is it me???I have a 1994 camry LE, with the I4. Its a coupe. How do I know what diameter the rear sway bar is, because I need to replace the bushings and they offer a 15/16mm, and a 17mm. Thanks, any advice appreciated.
