Hello group I hope you are super good, a small question that means the acronym ACT that you see in the diagram I would like to know what signal the cable should send is the lt gr / blk which sends an ACT signal but I do not know what it is .
Thank you very much for answering my friend, see that I disconnected the cable that sends the signal; to the ACT and literally nothing happened, should I have done something? check if there was voltage from the module what I did was use a test lead used to test fuses etc and when grounding the compressor it turned offACT - Provides power to the A/C Amplifier.
VOLTAGE AT ENGINE CONTROL MODULE (ECU) WIRING CONNECTOR
9.0–14.0 VOLTS (ENGINE IDLING AND A/C SW ON)
BELOW 1.5 VOLTS (A/C SW OFF
A/C - Receives voltage from the A/C Amplifier.
A/C – E1 : BELOW 1.5 VOLTS (ENGINE IDLING AND A/C SW ON)
7.5–14.0 VOLTS (A/C SW OFF)
