2005 coroola s auttic 134k
2k miles on oil change, tire roations, air filter 5w-30 full synthetic no leaks, no burning, 5k miles on ngk plugs gap checked, maybe 2-5k miles on previous maf,throttle body cleaning with appropriate different sprays etc.
in last 150 miles I did the following:
-Updated toyota intake manifold gasket, throttle body gasket, thourough cleaning of throttle body
-New valve cover gasket and grommets with the rtv ast cover/block joints
-New timing chain tensionor
*New pcv on the way. I verified which one of the two options I had before ordering.
noticed some oil build up on passenger side so cleaned and did the above work little over 150 miles and now this randomly happens.
sitting at stop light in park, drive or neutral I will feel in the seat a very slight random rough idle. not enough to set off soft or hard codes.
I went over all the vacuum lines and no cracks, everything is plugged in and clicked when i plugged things back in.
Where would you start if you feel the MAF is clean, throttle body is clean, newer plugs, and all the fresh gaskets?
Maybe 3 times a year I'll run a tank of premium no ethanol it may not do anything but I just did it with previous gas vehicles. I did run one can of seafom when I first bought it because it sat for two months. large tree branch fell and caved roof/broke rear window of dads girlfriend last year. Bought it and put new tires and rear window and hammered roof and been driving great. but the random rough idle wasnt there till I did all the work so wondering what to try next.it doesn't stumble the car I feel it on my bum if if really paying attention etc. Drives perfectly fine otherwise though.
