Last year I picked up a set of Konig Zero-In 17 X7 with 40mm offset off of craigslist for a really good price. I bought a set of 3mm hub centric wheel spacers and attempted to install them yesterday. I placed the spacer on the hub and then struggled to get a lug nut started on the wheel. After about 30 seconds of struggling, I realized the chamfer on inside of the hub centric ring (installed in the wheel) was too large not allowing the wheel to rest on the hub. Without the 3mm spacer the hub is long enough to pass through the chamfer and rest on the wheel. With the spacer, I still get 5 good turns by hand of the lug nut. Without the spacer, I get about 7 turns.
Is this number of turns safe in your opinion? Also, is it safe for the wheels not to be resting on the hub? I have no intensions of installing longer studs for this project. I just wanted someone else's opinion.
Thanks in advanced!
Cody
Thanks in advanced!
Cody
