YotaRunner4 said:
My gas gauge needle just hit the bar/line under the 1/4 full mark and my Low Fuel Indicator came on. Every other car I've owned, the Low Fuel Indicator didn't come on until the needle was just about to hit Empty. I was surprised it came on so soon. So I pulled in to fill up and it took 14.4 gallons, which means I had about 4 gallons left. Is this what everyone else is experiencing?
Absolutely.
It seems to be getting more common these days -- the 2004 Honda Accord I traded for my Camry was pretty similar, with the low fuel light coming on much earlier than I've ever seen before.
I did my best to scare the bejeezus out of myself and run my Camry out of gas a month or so ago, and here's pretty much what I discovered:
Again, as everyone is reporting, the low fuel light will come on with about 14.5 gallons burned, and thus about four gallons still in the 18.5-gallon tank.
With my XLE's multi-function display, the "cruising range" display will get down to zero pretty near the point where the fuel gauge hits the "E" mark. There are still about two gallons in the tank at this point.
The bottom line is even when the car is screaming at you that it's out of gas, as the fuel gauge drops below "E" very quickly after initially getting there, you've still probably got more than a full gallon in the tank. You could really consider the "E" mark as being a whole lot more like the "low fuel" light in previous cars you've owned -- you've still got a couple of gallons in the tank, and plenty of time to get to a gas station, unless you're waaay out in the sticks and far from civilization.
