When to Replace Power Steering Fluid?
3.7K views 10 replies 8 participants last post by  ag6286
I have an 03 Camry XLE with 30,000 miles. I am getting it serviced and having the coolant and transmission fluid changed. Should I change the power steering fluid now as well?
I get mine flushed at the dealership every 60K miles. I know everyone tell's me its not needed. But i've gone thru a few p/s high pressure hoses in my lifetime...its like a $79 service at the dealerships, for $79 i do it for peace of mind, not cus 'its' needed. 70 every 4-5 years ain't to shabby IMO!
I need to flush mine. The fluid is black and looks like a thick clay.
Wow really? i have a 96 also and mine is't black and thick.
I have beenthinking of doing that on mine but been afraid to do itt because when i had a minivan i changed the fluid with regular power stering fluid and i started laking a few drops a day. If i do it on my camry and use valvoline max life MerconIII dexron will it develop any leaks?
#11 · (Edited)
EASY, simple way to flush power steering DIY for any engine w/HYDRAULIC radiator fan. Disconnect the top mount bolt, turn on the engine and drain the majority of it out (should all come out withing about 30-60 seconds) then drive for a while. Done that plently of times (by accident) cuz mine was broken, it works very well. :D
dont disconnect the out-going tube, because it will splatter everywhere in ur car as u drive....HOWEVER, that is an easy way the give the engine a good shine :naughty:
P.s. if u drive, dont worry bout any white smoke, itll go away soon :ugh3:
