Where is the interior fuse box in Highlander 2021 ?
36K views 16 replies 11 participants last post by  denizel78
Where is the interior fuse box in Highlander 2021 AWD XLE ? I could not find it under the steering wheel.
Is there a always-on USB or 12 V power outlet for a dash cam?
#9 · (Edited)
The non-hybrid models have three fuse panels - two under the hood (above each fender) and the third near the drivers left knee under the dash. The hybrid models have a fourth panel in the passenger rear quarter near the battery. Here is the layout for the "under dash" panel. Fuses may be present or absent depending upon the trim level.
#11 · (Edited by Moderator)
Hello Gents, I have got blown fuse in my car Highlander XLE Hybrid 2021, do anyone knows, which sistem protects fuse ECU-IJ1 NO.3 (7.5A), in which reason or case my happened?Replaced fuse and blown again, also air conditioner not cooling 😞
Do someone has each fuse protection information list?which fuse protecting for what system?
#16 · (Edited)
The list contains 2GR-FKS (3.5L V6) / T24A-FTS (2.4L 4-cyl turbo) / A25A-FXS (Hybrid). Circuits unique to the hybrid will only show the A25A-FXS engine.
Example:
Toyota documentation can be confusing. It wouldn't be Toyota if it wasn't. Case in point: in odd Toyota fashion, circuits that are common to all engine models will either:
  1. Make no distinction between engines.
  2. Show each engine individually.
This post has been deleted
