Chasing down a demon right now with a crank no start on my 97 1mz fe Camry. Only time I can get the engine to fire is when the throttle is completely pressed down, which stalls out if I let off the gas.
Wondering why this is? I’m at a loss. Fuel pressure test read 45 psi, took spark plugs out and cranked, had spark.
Some important information:
New coil packs, plugs, wires. Pretty much a tune up.
Ran fine prior to me touching around. Like no issues, just a mild idle shutter.
The spark plugs are fouled. Caked with black carbon. ECT and IAC seemed fine on OBD scanner. TCS was also fine, not stuck.
Really I have no idea what to do next. I haven’t checked compression, I don’t necessarily have the means to do so (I’m a student, not much time to work on my car but I do want to fix it!)
Any advice lads on what I should do next?
