I have a 2003 Camry and recently replaced the window in driver's side front door b/c the glass had separated from the brackets. But afterwards, the window would no longer stop when it reached the top. The window would immediately start going back down and the only way to close the window completely was to turn off ignition or pull out wires to the window motor when it reached the top. I have been unable to locate another window motor with 5 terminal wires (5 pin) I can find then with 2, 4, or 6 terminals. A 5 pin motor advertised on Amazon had 6 pins when I received it. Has anyone else had this issue with locating a motor with 5 pin plug? The window never did operate properly, as it would not always stop when trying to lower it just a small amount
