Hey all,
So today my wife was driving and all of a sudden the radio went out, then the car said something about the ABS and air bags and it having to goo immediately to the dealer, then it lost power steering...she was able to get to the side of the road and the only thing that was working were the hazards.
We got it home. The tow truck driver was able to use a jump pack to start it and drive it into our drive way. I had him jump it again and I metered across the battery and it was showing ~6V. So I figured the battery died and that maybe killed the alternator. Or the alternator died then the battery died powering the car. There were no indicitaions that either were bad leading up to this.
I removed the battery and alternator and had them tested at O'Rielly's. Guy said both were shot. I know the battery may have been OK if it was just the alternator, but it was 5 years old and I figured I'd replace them both.
So I put the battery in and turned the key quick and it didn't do anything. I figured that maybe there was something smart in the car that prevented me from doing this since the alternator wasn't in and the serpentine belt was also just hanging there. I thought, "Man, Toyota is smart...that probably saved the belt which is just about brand new."
So I proceeded to put in the alternator. I forgot to disconnect the battery and got a bit of sparks from the alternator lead when it hit the alternator body, which was touching the block. Yep, I forgot to disconnect the positive. Rookie maneuver! Doh!!!
I stopped and disconnected it the positive lead of the battery. Installation went pretty smoothly after that.
I button it all up and still no starting. The horn works. The hazards work, and the dome light works. but no radio. No starter turning.
I took a multi-meter and checked all the fuses in the engine compartment; none were blown.
I then took a continuity reading between the positive terminal of the battery and the post that's marked '+' on the upper left side of the fuse compartment (see image below signature, post circled in red). I figured that is probably where the power comes into the fuse block. It read nothing (i.e. it was an open circuit) and the voltage read 12V between that post and the battery's positive terminal. I figure that should have read 0 ohms and 0 VDC between those two. I also took a reading from the main post of the alternator to the positive post of the battery and it also read 15MOhms. I figure that should read about 0 Ohms or so also.
So, is there a main fuse somewhere between the alternator and the battery and/or the battery and the fuse box?
Also, I'm still getting three errors on the screen.
- Brake Malfunction
- Check SRS Airbag system
- Check ABS
I'm hoping that the computer just freaked out when the power went to zero and popped these warning and they will be reset once the ECU gets power.
Vehicle: 2013 Highlander
Model: Plus
Engine: 2.7 L 1AR-FE
Miles: 130k
Thanks for your consideration
V/r,
hEdly
- Brake Malfunction
- Check ABS
Model: Plus
Miles: 130k
V/r,
hEdly
