I recently replaced all 4 fuel injectors on my 2000 Toyota corolla. I did so because I began to notice a strange vibration/rattling that seems to increase the longer I come to a stop. It would start from hood and make its way to the dash. However, rpms remain consistant (no jumping) Only occurs while stopped and while under load (in drive or reverse ). I do not notice it on highway, only when I come to complete stop.
Long story short. The new fuel injectors (denso) made the issue worse and my rpms were jumping all over the place. Car almost stalled on several occasions....I actually bought two sets (8 total) so I tied putting in the other set thinking I may of had a defect. Same thing happened though. Had to reinstall the old fuel injectors and now it's back to normal.
That said, here is what it's not: oem denso ignition coils last year and tested with multimeter to make sure there was no problem, new spark plugs, alternator charging all components, fresh oil and filter every 3k...
I also tried unplugging negative terminal battery after installing new injectors for several minutes hoping computer would reset but it didnt help.
Last idea I have is a bad fuel pressure regulator but why did the issue get more pronounced when I changed out the old injectors with brand new OEM ones?
So confused on this one. I've literally tried everything I can think of. May just live with it.
The Injectors were 45 dollars off ebay but they are denso and match the green oem I'm my car. Also the chances that BOTH would be bad is unlikely? In total I spent $90 dollars. The other set was going to be for my other corolla when I needed it.
I'm considering getting other fuel injectors from somewhere more reputable but fearful I will get same problem and will be out the money I spent on the fuel Injectors.
Anyone have any ideas? Any help would be much appreciated!
