X-Runner turbo kit
17K views 13 replies 10 participants last post by  runerules05
Has anyone put one of these on? If so how is it, did you install your self. Think its better than the super charger? Would it work on a PreRunner?
http://www.coast2coastperf.com/
Its on their site
#4 · (Edited)
Yes, the tighter road tuned suspension, the X Brace that increases frame rigidity (also give the X-Runner it's name), the sporty road tires and rims, different final drive ratio (differential gearing), and the thicker anti-roll bar. The X-Runner only has 7.5" of ground clearance a opposed to the prerunners 9.5.
The biggest difference is the suspension
The prerunner has the same suspension as the 4x4 but without the front drivetrain. The X-Runner as a completely different suspension all it's own.
The only difference from a turbo perspective is that the prerunner has more room. The kit will work on a prerunner. It's my understanding that it hasn't been released yet, although URD has a supercharger available right now. Trd is also close to releasing their 'charger, but they have been saying that for years.
to answer your question about a diff. in turbo or supercharged, turbo charged suffers from lag in the lower rpm range. the s/c gives you instant power starting as soon as you step on it. however, there is some sort of minimal loss called "parasitic loss" because of the fact that it requires some engine power for it to run. and i think theyre generally more expensive ?
not always true about superchargers having no lag, centrifugal superchargers (the ones that look like turbochargers mounted to the engine) are identical to turbochargers other then some differences in turbine design, they do have something resembling turbo lag because the engine has to get up to the right rpm before it can start building boost. With that said, i believe the URD and the supposed TRD chargers are not centrifugal superchargers.
i dont really agree with the turbo charge lag because it really depends on what size turbo you get. a smaller turbo spools faster and benefits from readily available boost but lacks at higher rpm speeds. a bigger turbo takes longer to spool up but offers more power at higher rpm speeds. in short get a small turbo for taking off "drag racing" and get a bigger turbo if you want to pull on someone on the highway.
