Hello TN....need your help!!!!! I have an 4cyl 02 Camry LE and I'm getting an P0420 trouble code. I've changed Air/Fuel Ratio Sensor that comes off the front Cat Converter and the rear 02 Sensor that is off of the rear Cat and I'm still getting that code, so as a result I'm changing the front converter that comes off the exhaust manifold. Now my questions is:
#1. Do I have to put any type of compound or anti-sieze on the new gasket that goes over the cylinder head studs?
#2. Do I have to put any compound or anti-sieze on the O-Ring at the bottom of the front Cat. as well before I re-assemble everything?
