ehhh, decided to open new thread, maybe someone who had such problems would find it and chime in ...
bacground info:
2002 Solara SLE immobilizer system is same as on any 97-01 Camry XLE with immobilizer. it's a simple Type 1 system.
long story short:
immobilizer on my car stopped recognizing master key transponder and from 2 working ignition keys I ended up with only one, but working now as a valet key.
went to dealer for diagnostics and they said ECM is not communicating with something, but wiring is good. they wanted to charge me $1350 for new ECM and labor on re-programming keys I already had (now have 3 of them), so I said no.
bought a used ECM just like mine on ebay at $60 and got it unlocked at locksmith at $150+s/h. unlocking is actually some kind of reflash procedure and it returns the ECM immobilizer programming to factory defaults just like it was before any keys were added/programmed.
I followed instructions on "programming keys" into a factory fresh ECM which are as easy as inserting keys into ignition lock one by one and waiting 5 seconds after each for ECM to write the transponder code down... but the ECM stopped programming procedure after first key...
end result, only first key got programmed (different than on other ECM) and ECM does not accept anymore keys.
tried adding more keys following the manual brake/gas pedal "programming" and it does not work. simply because the only working ignition key is (again) not a master, but rather a valet key :facepalm:
so now I have 2 ECM's and each one has its own working ignition key, but none of them allows programming more :facepalm: ... what's going on here? :wtf:
I seriously doubt that ECM (neither of them) is at any fault here, but what is then? :wtf:
here are instructions on programming this immobilizer, they do not work for me (used to work in past):
http://www.automotiveforums.com/vbulletin/showpost.php?p=3196858&postcount=7
bacground info:
long story short:
