'03 1ZZ-FE VVT Solenoid questions (cleaning, etc.)
8.2K views 9 replies 4 participants last post by  ViperR1
Hey all,
Decided to clean my VVT Solenoid and replace the Oil Control Screen/filter.
Parts are on order. New O-ring for the solenoid after cleaning with the mild CRC MAF spray, new oil screen & gasket for the bolt/plug. Looks like an easy job and removal of the alternator is not needed by the YT vids.
The screen & bolt/plug gasket are are a given, but my question is the polarity of the solenoid.
The vids show jumping the removed solenoid with alligator clips with a 9-12V source to pop it open and closed for a good cleaning.
My question is the polarity of jumping the contacts and which is + and which is - on this two wire set up. I don't want it reversed and chance it possibly damaging the solenoid.
Thanks all!
Oh, I'll post part #'s for what I got and if they are correct.
Mine is an '03 US made (1 on the VIN). Not 2 or J.
That’d be appreciated. I found a leak in my solenoid and a new o-ring didn’t solve my lean fuel issue. And I noticed you mentioned a gasket for the screen bolt which I wasn’t aware of so maybe that is the culprit.
#9 ·
Hey gang,
Been awhile on this, but I wanted to post findings.
1st, 9v is not enough to fully cycle the solenoid for cleaning & checking travel. 12v was better with my other clip set up on the battery. Cleaned it from there, but still some cycling hesitation, so I just bought an OEM Toyota from a dealer down the road. Don't but a cheapie after for $35. Go with the $116 OEM from a dealer and not ebay or Amazon. Just repackaged China junk no matter what they say. OEM comes with an O-ring and put some grease or SiliGlide on the O-ring and will go in smooth.
Screen was was filthy with full of clogs and broken plastic hampering the oil flow. OEM part on that too, with a new bolt gasket. I can list the parts if you want them. Oil screen plastics broke apart on removal, but got all the fragile tabs out. Be observative.
Solenoid was fine taking out and installing, but it was the screen bolt and screen was a pain for both taking out and installing without pulling the alternator. I toughed it out after about 2 hours to get it all even without the alt removed.
All in all, went good. No oil leaks after. I can tell the difference big time.
Worth the effort. 2003 1.8L 1ZZ-FE #1VIN North America built.
Almost forgot....don't worry if the new oil screen tab dislodges from the bolts center hole on assembly. Especially if you don't remove the alternator. It doesn't snap in very tight. It bottoms out in the engines recess, and as you thread in the bolt, you will feel resistance as the bolt reaches the tab and indexes in the bolts center hole. It's not going to float around or get sucked into the engine. A mirror and a light in the hole proved that.
Drove it today and all is smooth.
