2003 Camry i4 XLE, 200k
BACKGROUND FROM THE OTHER DAY
Bought this sucker for $300 4 days ago and the original codes I was getting were:
1. p0300 - Random cylinder misfires (I think)
2. p0301 - Cylinder 1 misfire
3. p0303 - Cylinder 3 misfire
I/M test fails:
1. Catalyst monitor incomplete
2. Evap system monitor incomplete
3. Oxygen sensor monitor incomplete
4. Oxygen sensor heater incomplete
You guys admonished caution and that I absolutely check the head gasket (which I did using an AutoZone radiator bubbly kit with blue water that turns pee yellow if carbone monoxide from the exhaust is impinging into the radiator cooland fluid). You guys also admonished that this year Camry has engine parts made of aluminum and the head bolts can strip the holes they're in --I tried to really look for that.
I bought the car super cheap:
I noticed it was leaking water like a seive --I pulled off a water pump and serp belt replacement; it was tough getting that belt back on but I did it.
For for a noob like me this is sort of amazing --the only belts I had taken off up to then were off of chicks and off of me:
Exuberant with my repair, I drove around with no water leakage at all (and normal coolant temp) but noticed the car kept wanting to die after coming to stops at light and stop signs; I had to keep the rev's up in order to keep the engine alive.
I reported these results back to Toyota Nation yesterday:
You guys' general consensus was to not worry about the I/M stuff for now and to first focus on getting the electrical stuff sorted out ("Bro, the cyclinder misfires might clear up if you have the power situation taken care of..."). Then drive the car around a bunch and see if the I/M stuff re-sets and gets sorted out naturally.
Okay, so today I went about trying to sort out the electrical stuff:
I bought a new battery; it cranks fine but the engine does not fire and come alive.
Instead, all the previous p codes listed above are gone and instead it threw a totally new p0335 code "Crankshaft Position Sensor A Malfunction" --I'm sorta nooby and I've never seen this p code before.
How bad i$ that code, as a general thing..?
I called AutoZone and they said a Crankshaft Position Sensor is $112, O'Reilley's states that it is $95. Freaking Ebay say$ it's $11:
WTF...?! What the hell, I order the cheap Ebay part from Guanghzong slaves chained to factory machines, I guess, dayum....
Crankshaft Position Sensor 'A' Circuit
Read more: https://www.autocodes.com/p0335_2007_toyota_camry.html
I looked up code p0335 and here's what it says for the 2007 (note I have the 2003):
Possible Causes:
Faulty crankshaft position sensor
Crankshaft position sensor harness is shorted or "OPEN" (..??)
Crankshaft position sensor circuit poor electrical connection
Signal plate maybe be damaged
Starter motor may be faulty
Starting system circuit
Dead or weak battery
This code is thrown when the ECM fails to detect the crankshaft position sensor during the first couple seconds of cranking.
I'm pasting below a photo showing where **I THINK** the crankshaft position sensor is. But remember this photo is for the 2007 and I don't know if it also accurately covers the 2003.
My Questions:
1. How should I proceed..? For the hell of it I ordered the cheap Ebay Crankshaft Position Sensor, since it appears to offer such an incredible value. I'm thinking I'm going to swap that sucker in there
2. How expensive generally is this repair..? Is my crankshaft all f*cked up..? That sounds kinda scary.
3. Do you have better photos of where this thing is on the 2003..? I have never seen this thing before, or maybe I have but didn't know what the hell I was looking at and so did not take note.
4. Thanks for your stellar advice, so far, you guys have been dead-on in your various assessments, it appears.
I/M test fails:
Possible Causes:
My Questions:
