Bought an 05 corolla CE and it had a buzzing/rattling sound on the right side during acceleration and clicking on speed bumps. Mech said the Captive Nut for the Engine Mount Bolt to the frame had broken loose. They said it wasn't part of the drive train (??) and that it looked like someone put a wrench on the bolt head and caused the nut (welded inside the frame) to break loose. So now the bolt/nut are loose and rattles. They put a zip tie to act as a temporary spacer to keep the noise down. The dealer didn't want to touch the repair job.
I would have thought that over-torquing the Engine Mount Bolt would have broken the bolt before the nut would come loose. A good weld should not have broken, don't you think?
In any case. Has anyone had this problem and been able to resolve it (inexpensively would be better). It seems like the frame would have to be cut (access hole), the nut removed from the bolt and then welded back onto the frame, and the access hole in the frame welded up. I figured Toyota doesn't want the liability for cutting on their frame.
Thanks
Thanks
