05 Taco Grease Zerk Question
1 reading
24K views 31 replies 15 participants last post by  LaPerouseBay
I have an 05 4wd Dbl Cab V6 Tacoma.
I was up under it today trying to study out where the grease zerks were.
I only found 5: Two on the front drive shaft and three on the rear, all in the joints. Are there some I'm not seeing? The 05 must have fewer than the older models - my dad says his has 11 (2000 and including balljoints).
Adrenalinate said:
Probably a really ignorant question but it wasn't until I got my Tacoma that I cared so much about doing self-maintenance. What are grease zerks? Are they grease injection points? If so, what type of grease and applicator would I need?
Yeah. Those are the plugs that you put the grease in. Just any grease gun from wal-mart or somewhere will do. I just wanna know if there's only five that I need to worry about, I didn't want to look over something and it go out in a few years. It seems that the Tacoma will be a really simple vehicle to maintain yourself, especially the oil changes and chassis lube.
#6 · (Edited)
Hey bluzman, I'm down in Somerset. We were just up in Louisville last weekend. We went down to 4th street live:whatwhat:
Adrenalinate, the Toyota maintenance guide that comes with your truck suggests you should grease every 5000 miles with oil change if you drive in desert or dusty offroad conditions. I'm not for sure for just regular street driving, probably not as often.
The Amsoil site says that the 4wd has 8 fittings, but the 2wd has 0 fittings.
:confused:
2005 TOYOTA TACOMA 4.0L 6-cyl VIN Code 1GR-FE
FILTERS
Oil Filter......EaO57/SDF57
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Series 2000 Synthetic 0W-30 Motor Oil
SAE 5W-30 Synthetic Motor Oil
SAE 5W-30 XL Synthetic Motor Oil
All Temps......5W-30
Manual Transmission,.....GL-4
All temps......75W-90
Synthetic Manual Transmission and Transaxle Gear Lube 75W-90
Manual Transmission,.....GL-5
Severe Gear 75W-90
SAE 75W-90 Synthetic Gear Lube
Automatic Transmission,5-Spd.....WS
Automatic Transmission,4-Spd.....TIV
Synthetic Automatic Transmission Fluid
Differential, Front .....GL-5
75W-90
Severe Gear 75W-90
Differential, Rear .....GL-5
Above -18°C......90
Severe Gear 75W-90
SAE 80W-90 Synthetic Gear Lube
Transfer Case,.....GL-4
75W-90
Transfer Case,.....GL-5
75W-90
Severe Gear 75W-90
Fluids
Power Steering Fluid.....AF3
Torque-Drive™ Synthetic Automatic Transmission Fluid (ATD)
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
Two-wheel drive
0 Fittings, 0 Plugs
Four-wheel drive
8 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
CAPACITIES
Engine, 2WDwith filter..........4.8 quarts[1]
Engine, 4WDwith filter..........5.8 quarts[2]
Cooling System, W/ MT Initial Fill..........10.0 quarts
Cooling System, W/ AT Initial Fill..........10.0 quarts
Automatic Transmission, Initial Fill..........2.1 quarts[3]
Automatic Transmission, 4-Shallow PanD Initial Fill..........2.1 quarts[3]
Automatic Transmission, 5-Shallow PanD Initial Fill..........3.2 quarts[3]
Automatic Transmission, Total Fill
A340E..........13.0 quarts
A750E..........12.0 quarts
A750F..........12.0 quarts
Manual Transmission, 2WD..........5.5 pints
Manual Transmission, 4WD..........5.3 pints
Differential, Front..........3.2 pints
Differential, 2WD EX Prerunner Rear..........7.0 pints
Differential, 4WD & Prerunner Rear..........5.9 pints
Transfer Case,STD..........2.1 pints
1. Except Prerunner
2. Prerunner & 4WD
3. With ENG automatic transmission operating temperature, shift through all
gears. Check fluid level in PARK and add fluid as needed.
TORQUES
Oil Drain Plug.....30 ft-lbs
Manual Transmission
Fill Plug.....27 ft-lbs
Drain Plug.....27 ft-lbs
#16 · (Edited)
They're up their you'll have to move your driveline around. The front one you can just rotate, but the back one you'll have to move your truck forward or back a little bit to expose them. I just checked that Amsoil site as mentioned above saw it has 8 fittings for grease on the driveline, :wtf:. I'd like to know where the other three are :confused:
#17 ·
It doesn't say where they are. It just states that there are 8. They could be wrong.
I just sent them a discrepancy report because they had 5.8 quarts down for the oil capacity of a V6 4x4 2005 Tacoma. 5.8 quarts is the capacity for the I4 4x4. The 2006 spec sheet for the V6 is correct with a 5.5 quart capacity for the 4x4.
#19 ·
I saw that too. On mine (05 4x4 V6 dbl cab) It will hold 5 quarts of oil with a new filter. After that it is over full. Like a dummy I put in the 5.5 qts listed in the owners manual without checking it and it was about a 1/2 quart over on the stick after I started it up and shut it back off, and I had to drain some. So it may be wrong on the grease fittings also.
#21 ·
well there ya' go, I have 2WD.
:confused:
FILTERS
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Severe Gear 75W-90
75W-90
Severe Gear 75W-90
Above -18°C......90
Severe Gear 75W-90
75W-90
75W-90
Severe Gear 75W-90
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
CHASSIS LUBRICATION
Two-wheel drive
0 Fittings, 0 Plugs
Four-wheel drive
CAPACITIES
1. Except Prerunner
2. Prerunner & 4WD
TORQUES
Manual Transmission
#22 ·
Just greased my zerks today with the help of a buddy. :thumbup: Only found a total of 5: 3 for the rear prop shaft and 2 for the front prop shaft.
Total of 5 should be the same for all the 4x4 models, regardless of cab size. Pre-runners I imagine only have 3??
Tips: The 3 on the rear are on the outside of the u-joints. The 2 on the front are inside the u-joints. Easy to locate as you can rotate, just like kytaco says. The rear zerk on the front prop shaft requires the removal of the heat shield to get to the fitting though.
ANYBODY FIND THE OTHER 3 ZERKS?!?!
#23 ·
Did mine yesterday. Looked for 8 and only found the 5 you did.
#24 ·
TacoSport05, I was able to reach the front prop shaft's rear zerk without removing the heat shield, but I will say it is a biiiooootch to get to the fitting! I reached around sorta over the top and was able to get it much easier than trying to go straight up from the bottom which I found is almost impossible with my grease gun.
#25 ·
I'll have to give that a try next time. I'll make sure to look for a grease gun with an extra long hose. My buddy's grease gun had a shorter hose I guess...
