1992 4age 20v Silvertop ac idle up problems
5.1K views 38 replies 6 participants last post by  Dalton7303
When my ac compressor kicks on the IAC looses power on a test light it actually shows ground when the AC compressor is on and the motor will sputter then stall. Does anyone have any ideas or know a link to a wiring diagram I could use?
We might have an interpretation or terminology issue here. When I think of IAC, I think of the IAC Valve (idle air control valve) that is located just under the throttle body. That IAC valve is not involved with the A/C system operation - at least in the aspect of increasing the idle speed of the engine when the load of the A/C compressor is added to the engine. Consistent with the wiring diagram provided by CanadianCorollaGTS, it shows the normal VSV1 A/C Idle-Up VSV, which is controlled by the ECU. When the ECU gets the input that the A/C compressor clutch has engaged, the ECU activates this VSV. The VSV then opens it's valve to allow air to flow into the intake manifold (bypassing the throttle body). It may be possible this VSV has failed, or it may not be connected to the wiring harness, or (if the engine in this application was swapped it) it may not even be present.
#21 ·
I think you may have resolved your problem then?
That VSV has a part number on the metal bracket, which I cannot make out on the picture. Perhaps you can make out that part number and provide? It would be in the form of xxxxx-xxxxx.
Also, in your picture, which was the hose that was collapsing, and what was that hose connected to on the other end? Sounds strange that a hose would collapse only when energizing the VSV.
#23 ·
If it was going to the intake manifold, then it would have been collapsed before the VSV opened also (there would have been intake manifold vacuum on one end, and the VSV would have been capped off on the other end, so the hose was under full intake manifold vacuum).
When you get home, see if you can get the part number off of that VSV. It looks very similar to the A/C idle up VSV I have on my 93 Celica convertible - just mounted in a very different place. It has an adjustable orifice opening screw on it to adjust air flow past it - meaning if your VSV actually works, the screw could have been adjusted to block off the orifice so that now air passes through.
#25 ·
I'm not entirely sure this diagram pertains to your specific vehicle, but it looks like it does. And if I look at this diagram properly, it appears you have the two hoses cross-connected (on wrong ports) of the VSV, based upon the pictures you previously provided. You may need to take a look at this diagram and your setup (when you get home) and evaluate your hose connections.
Thank you very much I will definitely look at that and try that out my car is a ae101 so that is very likely
#24 ·
#30 ·
Take both hoses off of that VSV temporarily - noting the proper way to put them back on. Put a new hose that is 2-3 ft long on the VSV nipple that the hose coming from your clean air inlet to the throttle body was connected to.
  1. With engine off and key out of the ignition, try blowing air into that hose. You should not be able to blow any air through the VSV. Does this past the test?
  2. If that checks our right, then start the engine and let it idle. It likely will idle a little faster due to the hose connected to the intake manifold is now sucking in air. Check that out and see if that hose removed from the VSV that is connected to the intake manifold is pulling air through that hose, or is pulling a vacuum on that hose by putting your finger over the free end of the hose. Does this past the test?
  3. Next, take the new hose you temporarily connected to the VSV and try blowing air through the hose. You should not be able to blow any air through the VSV. Does this past the test?
  4. Next, with the engine still idling, turn your A/C on. Make sure the compressor is engaged and that your radiator fans are both running. Does this past the test?
  5. Last, take the new hose you temporarily connected to the VSV and try blowing air through the hose. This time, you should be able to easily blow air through the VSV. Does this past the test?
After you do these 5 steps, provide feedback if all 5 were successful, or if any of the 5 steps were not successful. We'll figure this out yet.
#31 ·
Going to run through that tomorrow then get back to you, Im also cleaning my throttles they have a gummy liner
