Hi there,
Not sure if this is common with others who have the 1MZ-FE engine as I just got this car a few months ago during the summer.
Its fall here in Minnesota and was concerned about the amount of time the car takes to warm up.
Thermostat and ECT are new OEM, replaced about 2 month ago.
IAC replaced a few months ago (gummed up)
Temp gauge will get to half eventually and blow hot heat.
Temp does not change on highway so thermostat should be good?
I feel like it uses a lot of gas upon start up. My assumption is that the idle stays high longer to warm up the larger V6 engine.
I’ve noticed it also holds the transmission gears for a long period of time (5-8 min of city driving) not causing me to shift into third. My assumption is this is used to warm up the engine/transmission.
I would like the car to warm faster, to drop the idle which is using a lot of gas.
Is there a way to get the car to warm up faster aside from just driving it? Mechanical parts to check etc.?
