Hello. Working on my newest project. 1999 Avalon XLS with premium 7 speaker sound system. Purchased the the car with 150,000 knowing it would need mechanicals done (timing belt, cam and crank seals, water pump, valve cover gaskets etc.) The person i bought it from installed a very nice pioneer head unit DMH 1500NEX and back up camera. The back camera he installed with exposed wire outside so i started the process of cleaning up the wiring job. First, i pulled the head unit and noticed the factory wire harness plug was cut out. Ordered a new one to replace it. Second, i followed the cables he ran to behind the glove box to the factory amp and noticed he spliced into the blue amp plug with the new cables. My amp has 2 plugs a blue one and a green one. See pics. Ive been trying to figure out what harnesses i need to make everything work correctly to bypass the amp, but am stumped because the recommended metra harness 70_1761 is for an amp with 3 plugs. I also purchased the best bha 8112 harness that plugs into the factory radio connector behind the radio, which supposedly retains the factory amp, but have read that it may cause white noise and distortion with my new head unit. I have contacted the Toyota dealer i purchased my parts from and requested a wiring diagram for my vin for radio and amp harness. If anyone has that diageam, it would be appreciated. The main thing i need is the factory amp wiring diagram. I did find websites that provided the radio harness color codes. Unfortunately, my go to site, cardiagn, does not offer the full service manual for my car only the engine. My goal is to run cables from the factory amp plug wires, to the pioneer power and speaker wire connector and bypass the amp. I found this part number for my amp 86280-AC021, which is discontinued. Any help is appreciated thanks Carck.
