I drive a 2000 Toyota Avalon V6 3.0L and am having some problems with it.
When I first start it up in the morning, everything seems to run okay, but about 5 minutes into driving it, I notice the engine is starting to sputter a bit and when I stop at a stop sign, the engine is seems to be misfiring. I got the codes from the local shop and they say "Engine Misfire on Cylinders 2, 4, & 6."
I also notice that when the car really starts to sputter, my power brakes get stiff and I cannot stop easily.
I have already tried changing the Ignition coils on each of them without any change.
I was under the hood the other day and started the engine. Soon after, I tested some things by unplugging the Ignition coil to the spark plugs on each of them (cyl 2, 4, 6.) The engine got increasingly more bogged down as I unplugged them (this was a good thing.) I plugged them back in and then let the car run for about 5 minutes and then the sputtering started back up on it's own. At this point, I tried the test again. I unplugged each of the ignition coils on the front cylinders (2,4,6) again and was confused, because now there wasn't any change in how the engine was running. It was like the front 3 cylinders were not running at all. I unplugged all the wires to the Fuel injectors and the spark plugs and it didn't change the way the engine ran.
I have a feeling this may be an electrical issue but really have no idea. Can anyone help me?!
Thanks in advance!
Thanks in advance!
