It's been a while since I've been on here. (My little echo rarely has any problems)
Anyway, I encountered an issue the other day and just thought I'd share since I resolved it. Figured it may be the solution to someone elses issue maybe.
Ok. So my car now has a little over 370,000 miles on her. The other day I noticed a hesitation while accelerating, like an instant loss of power/ jerk. It didn't do it much at first and the higher the RPM's the less it seemed to do this. Once I got the car up to 60/70 mph it was pretty much unnoticeable.
I couldn't figure out what it was. Thought maybe a vaccum leak. Nope. Maybe a bad TPS or CPS (didn't end up checking those), Thought maybe a bad injector or O2 sensor (didn't end up checking those either). I did try some fuel injector cleaner though but saw no change. I had a feeling it had to be a sensor or something because the motor itself runs great other than the intermittent misfire.
So I drive it in to work this morning. (1 hour drive each way) and aside from the minor hesitation/bucking/jerking while accelerating, everything went pretty smooth so long as I had the car up to highway speeds.
So I get off from work and start driving home. The problem seemed to have dissapeared completely for the first 3 or 4 miles, then all of a sudden it started up again. Only this time it had gotten much worse. I could no longer get the car to go over 70mph and when I came to a stop the car sounded like it wanted to die (but never did). It took forever from a complete stop to get past all of the sputtering and hesitation/missing to get the car up to speed. It would keep cutting in and out (the motor bogging down, then gaining normal power for a second or two and so on and so forth). So I decide to take it to a shop to see if they can diagnose it.
The guy hooks up his code reader and looks at the car for a little bit out in the parking lot. He doesn't really have any idea whats wrong with it either. All he could do was suggest to change the spark plugs and said that that was where he would start. Didn't seem like he wanted to fool with it so I just took it back to my house and decided to mess around with it some more and see if I couldn't figure it out myself. So I went ahead and listened to what he said about the spark plugs (even though I knew there wasn't anything wrong with them because I had just changed them about a year ago) So I'm changing them out and when I take out cylinder 1's coilpack I notice it's wet. It seems somehow water or moisture had gotten down into there. So I dried everything off and changed the plug (the old one looked fine but I changed it anyway) and I went ahead and changed out all the rest of the plugs too (they all looked fine as well)
So after seeing the water around the #1 spark plug and coil pack, The injectors are right in front of there, so I decided to take the plug off the injector and take a look.
Sure enough, I took the plug off of the injector right in front of the #1 spark plug (far left spark plug) and wouldn't you know it, it had water down inside of it. I pulled the plug off of the injector next to it and it hadwater in it too (but not as much)
I have no idea how water could have gotten down in there but it did. I took a Q-tip and used it to dry up all the water down in there. Put everything back together and took it for a spin and everything was back to normal.
I couldn't believe it. I figured I'd have to end up spending a crap-load of cash on a new sensor and possible labor to have a shop figure it out and fix it but it turns out to be something as stupid and unthinkable as that. Don't know how in the hell water had gotten down in there but it did happen to me and I just wanted to throw this (long) story out there as just another idea to check for if your having a similar problem.
It's a long-shot that yours would be something this simple too, but it is possible. I'm just glad I didn't end up shelling out a lot of cash. I love this little car. The most reliable, low maintenance vehicle I've ever owned.
Take care peeps.
Take care peeps.
