2001 - 2003 Highlander steering wheel controls
2.4K views 6 replies 3 participants last post by  xinhuawang0101
Just wanted to let people know, you can add factory steering wheel controls to your early gen Highlander/steering wheel if your not wanting to replace the whole wheel. This is standard on first gen Sienna minivans. I suspect this would be a simple addition with just replace the clock spring or adding the wiring to your existing clock spring
I think you can get away with it because like the 01-03 HL, the stock gen 1 Sienna only has 6 pins as well. But you probably won’t be adding heating to your wheel if you want the volume controls.
May need to swap to 04-07 CS to have both. I’ve still been putting it off
