2001 Sienna Crank but does not start
15K views 10 replies 4 participants last post by  Daumas
Hi Toyota Nation
I'm looking for assistance to understand what can go wrong on a 127,000 Miles XLE Sienna with the VVi engine which crank but will not start.
During a commute going back home my wife mentioned that several lights turned on. According to her memories the VSC light, check engine light and Trac Off lights turned on at the same time. She did not noticed other problems and came back home as usual.
Once stopped home the car crank at its normal speed but will not start. It fires, almost start but does not.
Battery is recent, lights are turning on normaly.
There is gas in the tank, plugs and oil were changed 1000 miles ago, oil and coolant levels are OK and clean.
Gas cap looks all right.
Tried both keys still does not start.
I inspected and tested fuses and found that fuse 26 (ECU-IG) was blown and replaced it. Still does not start.
I tested with a tester all fuses and found as well that fuses 25 (mirror heater), 33 (starter) and 35 (Panel) where not alimented with the key on ON.
I disconnected the battery for one hour and reconnected, still does not start.
I bought an OBD2 code reader and it make the following readings:
- MIL status Off
- No Codes
- Misfire OK
- Fuel System Mon. OK
- Comprehensive Components Monitor OK
- Catalyst Monitor Inc (not completed in diagnostic testing)
- HTD Catalyst N/A
- Evap System Monitor INC (not completed in diagnostic testing)
- Secondary Air System N/A
- Oxygen Sensor Monitor INC (not completed in diagnostic testing)
- Oxgen Sensor HTR INC (not completed in diagnostic testing)
- EGR System N/A
I did not performed a gas pump pressure test yet and was wondering what else I should test and what could be the root problem.
Thanks in advance for your advices
#5 · (Edited)
Unfortunately, you might have erased the codes that lit the Check Engine Light by disconnecting the battery. Now that the car won't start, it won't reset the codes. You are caught in a Catch-22 situation. So you have to debug it the "old-fashioned" way. It is probably not the immobilizer if the car is "trying to start." That, to me, indicates you were getting partial ignition. You would get none if the immobilizer were blocking ignition. So I think you are down to determining whether the problem is spark or fuel. You can "rent" a fuel pressure tester for free from Autozone or O'Reilly's. They refund your deposit when you return it...so it's free. My fuel pump died on my Grand Prix. A fuel pressure check confirmed the problem was fuel pressure. It would die after running for a few minutes. The fuel pressure slowly ebbed away until it died. Now your Sienna isn't running at all. The fuel pump could have failed more catastrophically.
You can check for spark fairly easily by removing one of the 3 front spark plugs and seeing if it is firing when you crank the starter. All 3 front plugs would be easy to check. The back 3 are not so easy.(understatement)
Other things to possibly check?
Make sure the throttle body and Idle Control Valve are clean.
Look for any disconnected/cracked/broken vacuum lines
Thanks Robert, agree we are down to Spark or Fuel ...for now.
Fuel fuse and relays and OK under the hood but the pump does not make any sound when you open the gas cap. I dropped the gas tank, extarcted the pump, tested it and it does work. I will replace it anyway with a new one and I need to check if there is electricity at the gas pump connector. It may be a wiring or ground issue as well as we have a lot of salt in NJ and the gas tank fittings and nuts are very corroded. I will get everything cleaned up, back in place and will rent a fuel tester and test sparks. Agree that accessing the 3 back sparks is a pain to say the less.
Alain
Check out the crank position sensor. There are resistance checks that can be done.
#9 ·
Sienna 2001 stats but rumble. Codes 0172, 0300, 1346
Hi Toyota Nation
It is restarting and I managed to get codes!
I installed a new fuel pump, change IAC and throttle sensor, carefully cledaned up the two throttle bodies, and checked carefully for any cracked line for vacum.
To be on the safe side I changed the 6 plugs, changed manifold and throttle gaskets and gave a new try.
Engine started this time but is very hesitating and rumbling.
After 2 minutes of warming up the VSC, Trac Off and Engine lights turned on.
I connected an OBDII code reader and the following came out:
P0300 Random Multiple Cylinder Misfire detected
P0172 System too rich bank 1
P1346 Manufacturer Control
I suspect a problem with the Engine Controle Module.
Thoughts? Suggestions
