2002 camry: hard turning problems
Tags
steering
16K views 11 replies 6 participants last post by  SFCamry
My 2002 Camry is having some steering issues. WHen I turn it seems to hit harder spots then easy spots.
Some days its better than others.
I found one of my front tires was low and fixed that, it got better for a day and now is back (tire pressures are still ok).
At this point I'm worried about my wife driving it.
Any ideas?
#6 · (Edited)
Then you really SHOULD try this 1st...there may be air in the lines...
1. put TWO square sheets of plastic under each of the front tires...this will allow the wheels to turn smoothly on the ground.
2. open the cap of the PS reservoir
3. make sure the level is between min and max (minimum and maximum) lines (whether hot or cold)
4. turn the steering wheel from one extreme to the other slowly about 4 times...
5. any air bubbles in the line should now be purged
6. check the level again and make sure it's between min/max lines
...and with luck all will be well and smooth again
#9 ·
I did it with the car off and then on.
when the car is on, I get the hard/easy turning thing. with the car off, it is consistently firm.
I don't know if that means anything.
So I turned the wheels. I think the fluid level dropped a little. and I think it's a little easier to turn, but barely. I only did it 3-4 times. should I have done it more?
#11 ·
spray some PB Blaster on the U joint where the steering column and the rack meets. Turn the wheel a couple time to get it really soaked. It's should be below the brake booster. I had an issue with my friend's Camry (1995) that had a easy hard easy hard issue like what you was explaining. That fixed the issue. My dad's camry (2001) had an issue where it would not return back to center. I sprayed some PB blaster on the U joint and problem solved.
Check your struts to see if it could also be a spring/mount issue as well if those two do not fix the issues.
When done fixing it, a good idea (great idea really) would be to flush the fluid as Kitacamry indicated. Valvoline MaxLife ATF fluid is great for the power steering, and WalMart sells it for under $5 a quart. Takes a little prep but there is a DIY here that guides you through it. Makes your steering feel like butta when you are done.
