Coolant Change Toyota Camry 2003 LE 2AZ FE
How do I change my coolant?
Do I need a jack/jack stands/ a drive up ramp or can I just park it on a sloped driveway or on top of a curb and go under?
I have the jack for changing a spare tire, but nothing else, so will I need to buy supplies? If so, where at? I know I can change my oil by driving it up a curb.
Is Valvoline High Mileage Synthetic Blend 5w-30 good for my 03 camry with 145k miles?
Can I switch back to conventional or full synthetic or will I get my best results by sticking to the blend?
I watched some online tutorial videos about how you need to drain the coolant by pulling the drain plug, but I can't figure out where that is. I know for the engine oil, there's one down below, but what about for the coolant? Can I see a picture/video/further explanation?
Can someone give me a step by step tutorial?
I bought 2 gallons of Zerex Asian Vehicle formula, as I heard this was similar to toyota's and was silicate free, so it'd resemble my coolant, and the last time I had my coolant changed was at around 115k. Do I need to change it now? It was in early 2011 when I changed my coolant and I had about 115k on it. Or can I go a little further before changing?
And can I top off my current coolant (red asian vehicles formula) with prestone long life coolant because before this winter started (last novermber), my coolant level was a little below the full, so I topped it off by adding prestone to the pre-existing red import/asian coolant. Was this an OK thing to do?
And when I flush my coolant, can I use prestone, or is Zerex that much better, or is prestone coolant also going to do the job for a coolant flush?
Also, when I flush it out, do I just use water, or should I use an extra radiator flush chemical, like Peak Super Cleaner and Flush or Prestone super flush, or should I use the Zerex radiator flush? The guy at autozone said even if you fill it with zerex, you can use a prestone super flush, since that'll go out of your system and you'll drain it away, so that makes sense. Or should I use zerex flush ,because they didn't sell it. They sold the coolant, but not the specific zerex flush chemical, so can I use prestone and given my situation, SHOULD i use a flush chemical or should I just flush it with water?
Some people said I need to use a HOSE, but others said I should add some distilled water, let the engine run, then drain it out, then add in some water, let it run and drain it out n times until the substance coming out the drain plug is clear, so should I do that? Use a hose, or can I just manually add water, then drain it out?
And if I add zerex, can I top it off with prestone? Is zerex that much better/long lasting than prestone?
where is the radiator to this car and where is the drain plug/where I can remove the coolant?
