I just bought Monroe 172114 and 172115 front struts (the quick strut ) and the MONROE 171373 rear struts
FRONT STRUTS
The problem was the front struts. I set torque wrench to 29 ft-lb per repair instructions for the top 3 nuts that attach the strut at the top.
I was going in a rotating pattern fastening the 3 top nuts, going from one nut to the second and to the third. At some point I realized I wasn't getting to 29 ft-lbs as the bolts were spinning.
The 3 bolts where spinning and no longer fixed to strut's metal flange at the top. I had used the 3 new nuts that came with the package. I since noticed these nuts have slightly warped threads I guess to lock it in place. They were smaller than original nuts.
If the nuts are snug and the bolt is spinning with the nut when you turn it, do I need to reinstall the strut? The strut still cant go anywhere as its held down by the 3 nuts - but since the bolt is no longer fixed to the strut, I'm wondering if alignment will get messed up and/or if this is a safety issue.
I don't know how I'm going to take the nuts off either as the bolt spins.
UPDATE: I got one nut off....it was a huge pain. I had to grip the bolt threads. I'm wondering do I try to take the other two off....or just put the one nut back (if I can).
On the front passenger side, 2 bolts are good, 1 is spinning - although the strut is fastened with the 3 nuts....it can
t go anywhere....its just the bolt and nut spin together.
On front driver side, all 3 bolts are spinning as I was an idiot rotating the torque wrench around each nut trying to get up to spec.
Can I just leave it as is and drive or do I need to rip it all out?
I have since double checked torque wrench and it is accurate. I don't know why the bolts stripped off - unless the new nuts provided by monroe change the torque requirement. They were smaller than original nuts and had threads that seem to grip on so you can't back out. I'm so disappointed now...thought this would be a good confidence building DIY job.
FRONT STRUTS
