I should start with a problem that started last winter. I am in So. Cal when it gets cold 50 deg or so the headlights would be on in the morning. The fix was to leave them in the brights position. Winter ended, about 9 months it was fine and recently started again with the winter. Again just left the high beams in the on position at night.
Looking online it sounds like the headlight switch needs replacing. I had replaced it the year before it started blowing out my headlights. That fixed it. I just ordered one off ebay, hope to have it in a few days.
So now current major problem started about 2 months ago the day after it had rained and cold outside, I don't know if related. If I start the car and lights are on, if I take it out of gear, or use the turn signal or windshield wiper the inside lights go out, headlights, AC/Heater and windows.
If I start it a couple times, may be fine.
I was just able to run a couple of errands just fine, got home put it in park and lights out again. Also if the lights are out, I can't push the button on the gear shift to get it out of Park.
When it happened 2 months ago I took it to a shop that does electrical, 24 hour later he gave up, it is intermittent and was running fine and ran fine until last week when it started doing it again. And this week it started with the rain.
I have checked to see if there is any water getting in anywhere or near fuse boxes and all look dry.
Here is another thing I noticed. If all those lights and power goes out, I can still turn the knob to the orange lights and the next one with the lights on, and they do come on. I haven't been able to do anything to get the rest of the electrical to come back on.
Could it be the headlight switch causing all this? I drive food delivery so lots of stops/starts and beating the car to the ground. I currently can't work and not a mechanic. : Help! Thanks.
