I need to replace the driver side climate control panel. Can anybody explain how to disassemble the panel for access to replace this panel module. Does the front plastic cover panel just pull straight off or there is screws securing the panel?
I would appreciate your help on this.
I am assuming this module is bad as it blinks on frt. defrost for seconds on any engine start, then you have to manually set the fan speed & air temp. each time. It will not retain the previous settings.
Also the heater doesn’t work at all, even after raising the air temp. but the ac does work.
Thanks!
Thanks!
