2005 CE power locks? and keyless entry question
3.9K views 2 replies 3 participants last post by  Briand_oh
I just got a 2005 Corolla CE with the 5speed manual. It has power locks (i think) but not sure it they would be compataible with some sort of keyless entry. There is no door lock button on the arm rest however all the doors will lock and unlock when using the key in the lock cylinder. When I turn the door key all the doors will lock and unlock at once. So is there a keyless entry system that will easily install and work? Thoughts?
No. CE models have the wrong integration relay and are missing the required wireless door lock receiver.
You cannot add keyless without adding system to it.
Reactions: En3chix
If you do search, I posted back in 2014 on my RKE and remote start on my 04 CE. It added another $20 for a total of $150 IIRC. BUT '04 no chip on key (adds money for module) and they didn't integrate with coil signal, so in cold (like now, teens or lower, it doesn't necessarily catch with first start attempt). Shop will change crank time for free, coil input extra. RS has lead for coil input; I'm too lazy to hook up. AND, yes this summer I've fixed intake manifold gasket for orange one hoping that'd solve severe cold starting.
I added RS for the RKE and the two remotes included. HTH,
