Car: 2005 Corolla S automatic with 245K miles still on original parts (except torque converter).
I have been searching on google and this forum for blower not spinning. This one came closest http://www.toyotanation.com/forum/1...com/forum/132-corolla-9th-gen-1st-gen-matrix-2003-2008/1207490-no-blower-c.html but there has been no activity since 2015. My car is 245K miles still on original equipment. The blower just stopped spinning yesterday without making any kind of noise. It was working great before. Air flow was smooth and the speeds worked fine. It just stopped suddenly. Started the engine and the fan wasn't turning on.
My symptoms:
My first diagnosis attempts:
What is the condition to turn on the A/C light? Does the fan need to spin before this is turned on?
What I have *not* done yet:
Is there anything that I missed? I am having a tough time finding the location of the relay, blower resistors, and the switch connector. Unfortunately my googling was not successful. I found the 2004 Corolla wiring diagram but had no luck with 2005, 2006, and 2007. Thank you!
My symptoms:
- Broke down without any prior warning of being bad.
- Blower fan doesn't spin in *any* of the speed setting.
- Turning on the A/C doesn't do anything either.
- A/C light remains off even fan is set high in all speed settings.
- Blower fan doesn't spin even if I manually give it a manual assist.
- Blower fan makes no sound whatsoever like struggling to turn on.
- Using Corolla 2005 document # OM12891U, the fuses # 28 (A/C 10A), # 35 (M-HTR/DEF I-UP 10A), and # 41 (HTR 40A) - all appear to be good. Checked with ohm meter and continuity meter.
- I took out the blower fan. The power connector to the blow reads about 11.70V on all speed setting of the fan. However, it read 4.75V at one point in time on low, med, and high. I could not get it to read 4.75V again. This was tested with a voltage DMM so there was no loading on the blower resistors or the power source. Now it always read about 11.7V with the engine off or about 13V with engine on.
- Haven't checked the relay (where is this located?)
- Haven't checked the blower resistors (where is this located?)
- Haven't checked the switch connector (where is this located?)
- Haven't checked the blower yet (to be done tomorrow)
