2006 Highlander Hybrid Limited ABS/Traction issue
3.2K views 2 replies 3 participants last post by  Bear&Meg
2006 Highlander Hybird 230K miles
I've read that it "may" need a new ABS module. I just want to double check before spending the $800-$1200 on a brand new one. Vehicle was a relatives car. She had new tires, calipers, brakes/rotors installed. When driving the traction control light blinks, cutting power to the vehicle. The ABS light is on as well as check VCS light. If the vehicle is placed into FWD or AWD maintenance mode then the vehicle drives as if it were normal (we know not to drive it in those modes).
After putting the car into FWD/AWD maintenance mode the car then sent a code for left front wheel speed sensor. Thats been ordered.
Codes: c0205, c1368, c1345
What can I check prior to buying the new ABS module. I don't want to throw money at something if its not going to solve the problem.
Were the brakes etc. replaced by someone with diagnostic software capable of resetting Toyotas?
If not, I’d do a TN/internet search for how to perform the reset process without the tool or a trip to a mechanic or dealer may be necessary to resolve the brake system warnings
