Hello, this forum has been very helpful with helping fix my car. I have a 2007 camry CE 2.4L AT. In the beginning the engine light was on but not anymore.
The problem I had/have now is that my car did not crank or even do a clicking noise. Going through the forum and past experience I deduced it was the alternator. So I went ahead ordered a new one and replaced it. The car started at once even drove it around the neighborhood.
Came back to run an errand and the car did not start at all. Alright, went through the forum again saw it may be the the alternator fuse and what do you know it was! Once the saga of taking that fuse out ended you can tell that some of the connectors burnt out. So a new one was put in. (Pain in the butt removing and installing that fuse!) After that I tried to start the car and look at that! The car started with no issue and again drove around the neighborhood nice and smooth.
Next day? No start no crank. This time it was starter. I know because we actually had to tap the starter to crank it up. Fine, we swapped the starter for a new one. Once again it started and after waiting for a bit we went around the neighborhood. Turned it off and turned it back on to see if it would start again and.....nothing.
At this point it was suggested to me to replace the starter relay. I did. Again it would start fine but if you shut it off it will not start again.
This is week 3 of this and honestly I'm at a wits end with it. Hopefully someone can tell me if I'm missing something because at this rate I'll replacing the car part for part.
