Hi,
With the valve cover removed, and cam gears/timing chain visible, I can rotate the exhaust cam to where the timing chain is tight, between the intake and exhaust cams, and can also do the same to make it loose or create slack between the intake and exhaust cams.
Question is, when it's loose between the cams, how much slack is acceptable?
Thanks!
Thanks!
