Status
Not open for further replies.
2010 SE foglight bulbs switching to yellow?
2.7K views 17 replies 12 participants last post by  njerald
I removed the 3 screws that hold up the access panel to reach the foglight socket. I tried to turn the bulb socket clockwise and counterclockwise but doesn't seem to wanna give. Don't want to break it, am I missing a step?
Also I wanna change to a yellow bulb. Is it a H11? What is the highest watt I can go without melting anything. I just want a plug and play with no relay...
TIA
Please do a search as this has been covered several times.
Please check this thread out before starting a new thread http://www.toyotanation.com/forum/announcement.php?f=104
I believe they are H11 (check your service manual to be sure). Most aftermarket Yellow bulbs (Nokya) say they are stock wattage but actually run hotter with a risk of melting, some people have probs some don't. You can buy a heavy duty harness on ebay, it's plug and play... it hooks into your stock harness and then you plug the bulb in.
#9 ·
I think you should be fine without the harness, the DRL's dont draw that much voltage, so it doesnt run at its full potential therefore not creating that much extra heat. Unless you wanted to run your high beams 24/7 then you should but with just drl's you should be fine,
Don't worry about anything.
I've been operating exactly Nokya bulbs in my high beam/DLRs for over 2 years.
Since these bulbs are higher wattage, your DRLs are brighter but that's not a problem because that's still drawing far less watts than in "full on" setting. And even when you DO turn on your high beams, you never really run them for longer than 1-10 minutes so nothing happens.
I've inspected my harness, connectors and sockets and there's been no damage at all. Using over-wattage in your low-beams is an entirely different matter though. You should either use a separate harness in that case or go with a HID conversion (again with a separate harness).
Save
#14 · (Edited)
Serioulsy this is the 3rd thread TODAY made about this....Do a search PLEASE!..It's not that hard...
Before making a new theard please look at this. http://www.toyotanation.com/forum/announcement.php?f=104
Now all 3 of them have been merged to one...Hopefully my point has been made.
This post has been deleted
Status
You have insufficient privileges to reply here.
