2010 Starting Problems
1.9K views 11 replies 4 participants last post by  BlackCamSe
I have a 2010 Toyota Camry Le that has been giving me some problems lately and was hoping someone could help me out, it would be greatly appreciated. The probelm I am having is sometimes when I try to start my car it just seems to keep turning over and over but will not fire. It does it randomly. Some days it will start with no problem n then the next it does not want to start. If someone knows what is going on or if they have experienced the same with theirs and could help me out they would be a huge help, thanks.
typically, fuel pumps have a valve that holds pressure in the fuel line when the car is off. if the valve is faulty, pressure may drop between starts where you will need to crank it over for awhile to build up enough pressure to start the car.
but this is just a guess, it may be a completely different issue. it could have something to do with the ignition system, but we'll let someone else come on and elaborate on the possibilities there.
I also got this. MY dad is a mechanic so he told me this... "Ignition coil, Igniter or Distributor. Pull a spark plug and plug it back into it's spark plug wire. Turn over the motor and see if there's spark. You might need a helper or do it at night. There should be a small blue spark in the spark plug gap. Don't touch it. No spark...bad. A lot of Toyotas use the same igniter so they are cheap at the junk yard and easy to fix. "
On an older vehicle yeah. The 02 and up camrys use a distributorless ignition system. It's coil over plug. So 6 cylinders= 6 coils. Highly unlikely that all coils have a random no spark issue. Use a DVOM and check the resistance of the cam position sensors. And crank position sensor to be sure they're in spec.
