Hey guys,
So as some of you might know I recently elected to change the fluid in my 2011 Camry. I used and followed the Temperature Detection Mode to the letter except for two things that could be causing my issues. The first was that I also changed the filter which caused me to get a lot more fluid out. I think most people said on a drain and refill you only get out 2-3 quarts maximum and if I remember correctly I easily got 4-4.5 quarts. The second is that the vehicle may have been unlevel. I checked it with a torpedo level and ended up moving it to a more suitable place but was not perfectly level. It was also jacked up a little more on the front as opposed to the back so I guess it could have biased more fluid into the pan.
Okay so before this becomes complicated the reason I think it may be low on fluid is when I first put it into drive or reverse it needs extra acceleration to get it moving. I am no transmission expert but when transmissions have been low in the past these are the kind of symptoms I run into. There is also a little bit of "slipping" present while driving and I have been driving my truck since I noticed these symptoms. As always any feedback and advice would be greatly appreciated.
I figure I have two choices, one of which is to take it to a dealership and ask them to check the fluid level. I would like advice on this too. For instance, I think there are various ways to check the fluid, so do certified shops have a way to check the fluid level while it is warm/hot? Specifically, is it a red flag if they say the can check the fluid on the spot, should I expect them to keep it while the fluid cools to the recommended temperature etc? I ended up buying another gallon of Valvoline MaxLife so I still have some left over. So that leaves me with my second choice, which is to jack it back up, try to make certain it is more level this time, add a couple quarts to it and put it into TDM and check the fluid again.
