2011 Toyota Camry SE V6, US Made - Alternator
4.1K views 13 replies 6 participants last post by  JohnGD
hi guys, hopefully i can get some answers here instead of being scammed by my local auto parts store/mechanic shops.
my alternator on my camry has gone out at 100,100~k miles. i've been researching a lot of different shops/websites and have come up with different prices. i went to an auto parts store to inquire about a US reman Denso alternator and the total added up to roughly $400.. i politely said "next time" and left the premises. i looked online at websites like sparkplugs.com and rockauto.com and they're half the price of the one in the auto store (minus the core charge).
am i able to buy a Japan (re)manufactured Denso alternator from online and have it be compatible with my US built camry with no issues? am i able to avoid the core charge if i buy the part online? are there any other websites aside from sparkplugs and rockauto? if i were to buy the alternator from Toyota itself, would it be guaranteed brand new or would it be remanufactured as well?
i apologize if these questions are stupid, i am trying my best to navigate through my car troubles as best as i can without being taken advantage of. thank you in advance to anyone who comments.
5% Discount Code: FA0863AA6D8617
Expires: January 15, 2021
Found it.
yay!! thank you so much!!
i have another question, if you don't mind my asking. i'm looking at rock auto and some of their denso alternators are $130~ whereas some others are $160~, are the $160 ones better than the $130 ones?
i read somewhere that they are different grades? i'm not too sure what that means.
#8 · (Edited)
TYC sell brand new alternator with lifetime warranty and no core return.
This model should fit your car from your description: TYC 21137 supersede from (21136)
Link:
https://tyc.autocaredata.com/items/2-11136
More Information for TYC 211137
Scotty Kilmer mention on this video segment (@6.34mins), buying new alternator is better than rebuilt, and the rebuilt come from an failed that's repaired.
#9 ·
You can get a new one or a DENSO reman. As per current toyota OEM, it will be a DENSO reman ending in -84. A proper reman by reputable builders such as Remy etc would be a good choice. If not buy OEM. If getting an aftermarket one, then even Duralast (autozone) is fine since it will have lifetime warranty and local exchange. There are threads where some bought Bosch. Now I rebuilt mine on my Honda. If I knew a rebuild place near me, I would have let them do it instead of just using the kit. Properly rebuilt ones have appropriate parts replaced (rectifier, regulator, etc). I think others in Camry forum also stated a junkyard Denso would be better than AF new (YMMV).
With that said, a Denso reman or a Remy reman is good. Also depending on the source or type of purchase a core return is optional. Another option is to buy a higher amp one so that it uses less % output rather than overworking (but I am not an electrical eng). I did that for my sister before on an Accord where I got her a used denso Odyssey alt. That lasted her over 200k after which she sold her car. Not sure if it is still running or what. I opted that over a new AF one. Just my two cents.
Depending on how long I plan on keeping my Camry I was going to get a custom one built by DC Power Engineering..... They told me the largest alternator that can fit on the V6 (2011) is 280 amps which is a solid upgrade for the 105 amp or what ever the stock one is. It is also a $500 alternator and they stick by their warranty. You won't typically find an alternator like that in a Camry, but if you talk to the guys on the truck forms, they know DC Power Engineering Alternators are quality.
#11 ·
Denso is the manufacturer of the alternator, so select that if you can, even if it's a reman. You can look for the Denso sticker on your alternator. Look on DENSO Auto Parts
The US-made Camry would take 210-1127, which is a newer part number. Don't get the old part (210-0654). Beware that you pay return shipping for the core back to rockauto, there's discounted rate on their core return page.
Remy and BBB make aftermarket new alternators, but price-wise there doesn't seem to be much advantage. And you have to figure out which one is for the US market first. Don't end up with the wrong part.
Search Results:
2011 Toyota Camry V6 3.5L
Part/Stock #EngineQtyNotes
Alternator
210-0654Engine:
V6 (3.5L)
CC:
3456
1Note:
100 Amp; Exc. Mfd in Japan (SELL OUT. REPLACED BY 210-1127)
Label:
Reman Alternator
View
Buy
210-0737Engine:
V6 (3.5L)
CC:
3456
1Note:
100 Amp; Mfd in Japan (SELL OUT. REPLACED BY 210-1164)
Label:
Reman Alternator
View
Buy
210-1127Engine:
V6 (3.5L)
CC:
3456
1Note:
Label:
Reman Alternator
View
Buy
210-1164Engine:
V6 (3.5L)
CC:
3456
1Note:
Label:
Reman Alternator
omg that is super high amp and expensive. I think 130A would be fine unless you are planning for accessories also. I heard of that brand and there is one other in the high amp, performance area.
#13 ·
I just replace on 2021 Jan 4 for my 05 Camry V6 (1mzfe) with an TYC brand new alternator from Rockauto. Receive the package with shipping box with bubble wrap inside and item was well packed and no broken connector as reviewed on Amazon.com for TYC alternator. DC Power Engineering might make the best high output alternator, but the cost is really expensive for an daily driver and there's no reseller for DC Power Engineering in Canada and TYC is well priced for an new item and affordable for an average consumer.
Here's some picture before installation
318395
318396
318397
318399
