2013 Highlander AWD 2nd Gen Front Sway Bar Bushings
2K views 9 replies 3 participants last post by  RobertR1969
Hello All,
I have a front sway bar bushing that is apparently ripped and partly hanging out of the side of the bracket. The vehicle is swaying more than I think is normal and when I looked, this is what I found. I bought the new OEM bushings from a local Toyota dealer and drove the vehicle up on ramps. Upon looking under the vehicle, I found it is really too tight to get into there with the typical tools.
My question is, what is the best way, from underneath or better to take the wheels off, and tackle from the side wells?
Is lowering the subframe any help? If so, does anyone know a video link for this?
I can see the bolts coming through the subframe and there are nuts on the bottom. Are those nuts welded to the subframe, or can be unscrewed from the bottom?
The vehicle has spent the last 8 years in Florida and has little corrosion, thank God!
Anyone have pics or other advice?
Robert
#8 · (Edited)
So I got the old bushings out and the new ones in. This really made a big difference in the body sway of the vehicle. This is no race car for sure, but now it is driving much more stable.
I do not think the rear is in need, but will check.
I have included a pic of the old bushings, and when the left bushing was still in the vehicle. Notice how they have become flatter and wider than they should be. The sway bar was definitely moving more than it should.
The vehicle had a 65lb bumper bar added to the front of it when I bought it. There was a LOT of brake dive when the guard was on the vehicle. I am thinking the bumper bar contributed to the bushings going bad like this.
My advice, do not add a front bumper guard to such vehicles that are not really designed with a heavy duty or truck suspension.
#9 ·
Did you figure out how to fit some tools in there or did you try and drop the sub-frame?
