Hi. I found lots of problems listed about the liftgate, but not this particular problem. I'll dive in:
After pressing either the button on the dash or remote, the liftgate opens normally. After fully opening, it immediately closes. While closing it "hops" and vibrates what I consider a little violently. If I try to stop it the loud beep that you normally hear while closing goes off and continues until it closes and latches normally.
Opening manually by the rear "handle" it is sort of heavy to lift, and immediately "hops" it's way back down. It is pretty much unusable at this point.
I hope I have gave enough info to be able to troubleshoot. Thanks
