2015 Corolla S 6speed manual shifts to 1,3,5 R but not 2,4,6!
687 views 2 replies 2 participants last post by  roadlesstaken
Hi everyone,
I searched and couldn't find anything so am posting. My '15 Corolla S has 255k km and drives smooth as new. Today driving from stop, shifted to 1st fine, but wouldn't shift to 2nd. Easiily to 3rd, not 4th, easily 5th, not 6th. Reverse fine. Anyone have insights? No previous problems, clutch fine, engine fine. I have a 17 second vid on my Youtube channel that shows issue. See below. Even weirder: a few minutes of fiddling with shifter and now it goes into all gears again. Very worried about problem arising again!
Thanks!
First thing to inspect are the shifter cable bushings on the transmission side. The bushings will have premature wear on the center and will wear oblong. With the bushings being ok, then check the other end at the shifter base.
Thanks! Did so and couldn't see any problems. Ended up buying used shifter assembly and had it installed by dealer. Tech wasn't told details of problem, just that customer wanted assembly replaced. Tech told me later he test drove before install and didn't notice any problem but installed other one as per instructions. Said sometimes a stone or other object gets lodged in the area where cable connects to transmission linkage and that can block shifter movement. Anyway, he didn't inspect it so I have no way of knowing if that was problem or not! Second one works fine, but I kept the old one....
At least it's not parked in my backyard anymore.
Thanks again.
