Need some help here...I don't really want to be throwing a lot of parts at the car. Clunk noise has been an ongoing issue for a couple years. Oddly it started on front right, but then move to the front left. In the time it has started I've had the following done (or done myself).
Clunk Noise
Noise typically happens with any bumps or changes in uneveness of road where one front tire is above or below the other one. In the sound file I was going into my driveway which I usually have to turn into to get up in the driveway.
I did notice my front left lower control arm bushing looked bad / leaking maybe? I plan to change both lower control arms and the sway bar end links next. BTW...the new lower control arms I got came with a grease fitting (zirc). Should I grease before installing? Anyone rate the difficulty of installing these? The sway bar end links should be very easy, but I'm a bit nervous on the lower control arms...I don't know if there are certain things I should watch out for?
Thank you to anyone reading and replying.
- All four tires replaced.
- Tires have been rotated 3 times.
- Front struts & coils replaced. **Replaced with a strut / coil assembly.
- All front suspension, engine mount, and subframe bolts / nuts have been tightened to torque spec. **A couple bolts / nuts did take some turning to get to torque spec.
Clunk Noise
