Hello!
I have a 2018 Toyota Camry LE. the other day it went into limp mode on me and is throwing a oil pressure low code(P0524). I went to my local dealership and got a new oil pressure sensor ( The Oil Pressure & Temperature Sensor (#89448-06010)) and got back to the car and found out that this was the wrong sensor for my car and apparently there had been a transition at some point and the part my car actually needed was 83520 which is the oil pressure sensor and is located on the back of the engine right under the oil temperature sensor (89429F)
After i got that part replaced i am still throwing the same code and a additional (p0522) code and that says engine oil pressure sensor/switch "A" low which is leading me to believe that the information i got at my local dealer about the initial part was incorrect and there's a second oil pressure sensor somewhere i just have not been able to find it ANYWHERE!
IF anyone has ran into this issue and found out where the additional sensor is PLEASE let me know so i can replace it! The Toyota diagram is no help I've followed its dotted lines for 2 days with no sensor found!
